15 years agoSimulation fails when it goes into big design.
Ok guys, I have designed a small block that does some counting and put some signals to zero while its counting..
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
--use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.NUMERIC_STD.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY deadband IS
PORT (
CLKOUT: IN STD_LOGIC;
T3PWM: IN STD_LOGIC;
PWMB7: OUT STD_LOGIC;
PWMB8: OUT STD_LOGIC
END deadband;
ARCHITECTURE identifier OF deadband IS
signal EVBCONDB_reg : UNSIGNED (7 downto 0) := "00011000";
signal PWMB7_DB_reg : STD_LOGIC;
signal PWMB8_DB_reg : STD_LOGIC;
BEGIN
PWMB7 <= PWMB7_DB_reg;
PWMB8 <= PWMB8_DB_reg;
-- T3PWM Deadband
process(CLKOUT,EVBCONDB_reg)
variable prev_T3PWM : STD_LOGIC;
variable counter_en : STD_LOGIC;
variable count : UNSIGNED (8 downto 0);
variable multiplier : UNSIGNED (2 downto 0);
begin
case EVBCONDB_reg(2 downto 0) is
when "110" => multiplier := "101"; -- /1 divisor
when "111" => multiplier := "101"; -- /2 divisor
when others => multiplier := EVBCONDB_reg(2 downto 0); -- /32 default
end case;
if(rising_edge(CLKOUT)) then
-- if we see a transition, start the clock and enable deadband
if(prev_T3PWM /= T3PWM) then
counter_en := '1';
--count := EVBCONDB_reg(6 downto 3) * multiplier;
count := "00000" & EVBCONDB_reg(6 downto 3);
count := count sll TO_INTEGER(multiplier);
end if;
-- if we've reached 0, stop counting and disable deadband
if(count = "000000000") then
counter_en := '0';
-- else decrement counter by one
else
count := count - 1;
end if;
-- remember T3PWM for next time
prev_T3PWM := T3PWM;
-- and output delayed PWM outputs
PWMB7_DB_reg <= T3PWM and not counter_en;
PWMB8_DB_reg <= not T3PWM and not counter_en;
end if; -- if rising_edge(CLKOUT)
end process;
END identifier;
When it is in its own project, the timing simulation would show that it's all good. However, when I incorporate it into the big project, the timing simulation would fail, however the functional simulation shows that it does what its supposed to do. Then I thought its a timing problem, but the compilation flow summary says all timing requirements have been met. So what's up? Note: Within the failed timing simulation results, this thing doesn't stop counting and the counts are not normal, once in awhile it would jump to a number far away (not wraparound). Thanks.
