--- Quote Start ---
1. Create your waveform vector file in Quartus II
2. Export this file to vhdl test bench (file->export)
3. Click, asssigments->settings->EDA tool settings->Simulation , choose modelsim altera.
chooose compile test bench in native link settings panel, click test benches, click new,
chosse any name for test bench, in test bench entity write: <your_top_level_entity>vhd_vec_tst
in instance name write : i1
chosee the file generated in step 1 in test bench files.
3. Compile your project.
4. click, tools->eda simulation tools: run eda rtl simulation for functional simulation or run eda gate level simulation for timing simulation.
After this steps quartus ii opens modelsim an starts the simulation.
--- Quote End ---
Dear Tricky
I had made step by step with instruction of parrado and you. Now it notice error with i1. I don't know what would I do with i1. Can I change i1? Thank you very much for your help.
Please help me
This is error with Modelsim
--- Quote Start ---
# do Counter_run.do
# vsim -sdftyp /i1=Counter_vhd.sdo work.counter_vhd_vec_tst
# Loading C:/Modeltech_5.7d/win32/../std.standard
# Loading C:/Modeltech_5.7d/win32/../ieee.std_logic_1164(body)
# Loading C:/Modeltech_5.7d/win32/../std.textio(body)
# Loading modelsim_work.counter_vhd_tb_types(body)
# Loading C:/Modeltech_5.7d/win32/../ieee.vital_timing(body)
# Loading C:/Modeltech_5.7d/win32/../ieee.vital_primitives(body)
# Loading modelsim_work.atom_pack(body)
# Loading modelsim_work.cycloneii_components
# Loading modelsim_work.counter_vhd_vec_tst(counter_arch)
# ** Warning: (vsim-3479) Time unit 'ps' is less than the simulator resolution (1ns).
# Time: 0 ns Iteration: 0 Region: /
# Loading C:/Modeltech_5.7d/win32/../ieee.std_logic_arith(body)
# Loading modelsim_work.counter(structure)
# Loading modelsim_work.cycloneii_io(structure)
# Loading modelsim_work.cycloneii_mux21(altvital)
# Loading modelsim_work.cycloneii_dffe(behave)
# Loading modelsim_work.cycloneii_asynch_io(behave)
# Loading modelsim_work.cycloneii_clkctrl(vital_clkctrl)
# Loading modelsim_work.cycloneii_ena_reg(behave)
# Loading modelsim_work.cycloneii_lcell_comb(vital_lcell_comb)
# Loading modelsim_work.cycloneii_lcell_ff(vital_lcell_ff)
# Loading modelsim_work.cycloneii_and1(altvital)
# Loading modelsim_work.counter_vhd_sample_tst(sample_arch)
# Loading modelsim_work.counter_vhd_check_tst(ovec_arch)
# ** Error: (vsim-SDF-3250) Counter_vhd.sdo(0): Failed to find INSTANCE '/i1'.
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./Counter_run.do PAUSED at line 1
--- Quote End ---
