15 years ago --- Quote Start --- 1. Create your waveform vector file in Quartus II 2. Export this file to vhdl test bench (file->export) 3. Click, asssigments->settings->EDA tool settings->Simulation , choose modelsim altera. chooose compile test bench in native link settings panel, click test benches, click new, chosse any name for test bench, in test bench entity write: <your_top_level_entity>vhd_vec_tst in instance name write : i1 chosee the file generated in step 1 in test bench files. 3. Compile your project. 4. click, tools->eda simulation tools: run eda rtl simulation for functional simulation or run eda gate level simulation for timing simulation. After this steps quartus ii opens modelsim an starts the simulation. --- Quote End --- Dear Tricky I had made step by step with instruction of parrado and you. Now it notice error with i1. I don't know what would I do with i1. Can I change i1? Thank you very much for your help. Please help me This is error with Modelsim --- Quote Start --- # do Counter_run.do # vsim -sdftyp /i1=Counter_vhd.sdo work.counter_vhd_vec_tst # Loading C:/Modeltech_5.7d/win32/../std.standard # Loading C:/Modeltech_5.7d/win32/../ieee.std_logic_1164(body) # Loading C:/Modeltech_5.7d/win32/../std.textio(body) # Loading modelsim_work.counter_vhd_tb_types(body) # Loading C:/Modeltech_5.7d/win32/../ieee.vital_timing(body) # Loading C:/Modeltech_5.7d/win32/../ieee.vital_primitives(body) # Loading modelsim_work.atom_pack(body) # Loading modelsim_work.cycloneii_components # Loading modelsim_work.counter_vhd_vec_tst(counter_arch) # ** Warning: (vsim-3479) Time unit 'ps' is less than the simulator resolution (1ns). # Time: 0 ns Iteration: 0 Region: / # Loading C:/Modeltech_5.7d/win32/../ieee.std_logic_arith(body) # Loading modelsim_work.counter(structure) # Loading modelsim_work.cycloneii_io(structure) # Loading modelsim_work.cycloneii_mux21(altvital) # Loading modelsim_work.cycloneii_dffe(behave) # Loading modelsim_work.cycloneii_asynch_io(behave) # Loading modelsim_work.cycloneii_clkctrl(vital_clkctrl) # Loading modelsim_work.cycloneii_ena_reg(behave) # Loading modelsim_work.cycloneii_lcell_comb(vital_lcell_comb) # Loading modelsim_work.cycloneii_lcell_ff(vital_lcell_ff) # Loading modelsim_work.cycloneii_and1(altvital) # Loading modelsim_work.counter_vhd_sample_tst(sample_arch) # Loading modelsim_work.counter_vhd_check_tst(ovec_arch) # ** Error: (vsim-SDF-3250) Counter_vhd.sdo(0): Failed to find INSTANCE '/i1'. # Error loading design # Error: Error loading design # Pausing macro execution # MACRO ./Counter_run.do PAUSED at line 1 --- Quote End ---
