Simulate Arduino on a Intel FPGA board
- _AK6DN_
Don't use a Cyclone 10 LP. Use something like this:
https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=1046#contents
that has an Arduino compatible header footprint, and an embedded Arm processor subsystem.
If you HAVE to do in on a Cyclone 10 LP (which has no internal processors) then you need to implement an Arduino compatible processor as well as the I/O subsystems you need. It will not be 'easy'.
- sstrell
Not sure what you mean. Are you saying you want to implement an Arduino in an FPGA or are you talking about connecting an Arduino board to an FPGA?
- dicas3d
- Is implement an Arduino on an FPGA.
- dicas3d
If I Use something like this(https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=1046#contents) what I need to do? In the really I'm not wanna use an Cyclone 10 LP . To be more clear I'm going use because I'm going to use an Arduino mkr vidor 4000 Dev board and this board have an Cyclone 10 LP . I want to simulate on it an more simple Arduíno like the uno, but is an project for learning purposes.
- ShengN_altera
The Arduino compatible header expansion is Arduino UNO Rev3. Check picture below:
Probably have to create a design and make appropriate pin assignment in pin planner. Then, you can signal-tap those pins waveform.
Sheng
- dicas3d
There is an more ready to go thing. The niosduino project here : https://github.com/dimag0g/nios_duino but i dont know if using this i was able to program the bootloader properly using arduino ide. And I found another project with similar name that I dont know if is an bootloader ready to my case : https://github.com/sweehua/niosduino
- ShengN_altera
For Nios related question, probably you have to open a new thread in embedded forum https://community.intel.com/t5/Nios-V-II-Embedded-Design-Suite/bd-p/nios-II-embedded-design-suite for further confirmation.
Sheng
