dicas3d
3 years agoSimulate Arduino on a Intel FPGA board
What is the easy way to simulate an Arduino on an Intel Cyclone 10 LP?
ShengN_altera
3 years agoHi,
The Arduino compatible header expansion is Arduino UNO Rev3. Check picture below:
Probably have to create a design and make appropriate pin assignment in pin planner. Then, you can signal-tap those pins waveform.
Sheng
dicas3d
3 years agoThere is an more ready to go thing. The niosduino project here : https://github.com/dimag0g/nios_duino but i dont know if using this i was able to program the bootloader properly using arduino ide. And I found another project with similar name that I dont know if is an bootloader ready to my case : https://github.com/sweehua/niosduino
