13 years ago
simple VHDL program --> need help please
i have an external asynchronious signal (called "sig") which i have to count its rising or falling edges. i wrote a program which somehow ends very quickly --> after 2 rising edges, req_dist = 32 --> req_dist(8 downto 1)=16 .
is someone can see what is my problem ? thank you very much for help...
library IEEE;
use IEEE.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity encoder is
port(
CLK : in std_logic;
sig : in std_logic ;
reset : in std_logic;
req_dist: in std_logic_vector(8 downto 0); --required distance
arrived : out std_logic
end entity encoder;
architecture arc_encoder of encoder is
signal counter : std_logic_vector(8 downto 0) := "000000000";
signal distance : std_logic_vector(8 downto 0);
signal flag : bit := '1' ;
begin
process(CLK,reset)
begin
if (reset = '1') then
counter <= (others => '0');
arrived <= '0';
flag <='1';
elsif(rising_edge(CLK)) then
if(req_dist /= "0") then
if (sig = '0' or flag = '0') then
flag <='0';
if (sig ='1') then
if (counter < req_dist(8 downto 1)) then
counter <= counter + '1';
flag <='1';
else
arrived <= '1';
flag <='1';
end if;
end if;
end if;
end if;
end if;
end process;
end architecture;
    if sig is asynchronous, you need to synchronoise it otherwise you're potentially sampling it on a transition. You need at least a double register to avoid any metastability.
    Please Quote your code with [ code]...[ /code]
    You don't need "use ieee.std_logic_arith.all;"
    req_dist is a vector, i don't know how it is interpreted.
    Maybe you have metastability events. Put at least 2 D-FlipFlop on your signal "sig".
    Quite complicated to count signal edges.
    I suggest (not complete) :
         process (reset, clk)
          variable detect      : STD_ULOGIC_VECTOR(1 downto 0);
          variable count       : UNSIGNED(8 downto 0);
       begin
          if reset_n = '1' then
             detect := "00";
             count := 0;
              arrived <= '0';
          elsif rising_edge(clk) then
                detect(1) := detect(0);
                detect(0) := sig; -- sig after 2 DFF to avoid metastibility
                if (detect = "01") or (detect = "10") then -- detecting rising edge or falling edge
                   if count < req_dist(8 downto 1) then
                      count := count + 1;
                   else
                      arrived <= '1';
                end if;
          end if;
       end process;
    i can really see the metastabillity situation in signal tap.
    i understood how to implement a rising/falling edge by "detect" variable. but how do i combine 2 DFF to this program ?
    very appriciate your help !
    thank you !
    my input signal comes from rotary encoder which generates pulses while rotating...
    [ code]...[ /code]
    thats what i done : (its does not work , still the same situation ... maybe the incoming signal ("sig") is bouncing like you sayed...)
    what do you suggest to try ?
    begin
    if reset= '1' then
    detect := "00";
    arrived <= '0';
    final_sig <= '0';
    sig1 <= '0';
    sig2 <= '0';
    count_flag<= (others => '0');
    elsif rising_edge(CLK) then
    sig1 <= sig;
    sig2 <= sig1;
    final_sig <= sig2;
    -- rising_edge <= sig2 and not(final_sig);
    -- count_flag<= count_flag+1;
    -- if(count_flag > 3) then
    detect(0) := sig2 and not(final_sig); -- sig after 2 DFF to avoid metastibility
    counter <= counter + 1;
    else
    arrived <= '1';
    end if;
    end if;
    -- end if;
    end if;
    end process;
    first debounce significantly your 'sig' signal : very quite easy to write with other process with counter
    * that counts to a fixed value if no 'sig' event happens
    * that be cleared if a 'sig' event happens.
    For example, clk is 20ns-periode (50MHz) and you want to not consider pulse < 100us. So counter for this will count to (100us/20ns = 5000) if no event happens.
    Just little but important corrections here :
       -- variable count : UNSIGNED(8 downto 0); -- not used here
    begin
    if reset= '1' then
       detect := "00";
       arrived <= '0';
       final_sig <= '0';
       sig1 <= '0';
       sig2 <= '0';
       sig1 <= sig;
       sig2 <= sig1;
       final_sig <= sig2;
       -- rising_edge <= sig2 and not(final_sig); -- one way to detect rising_edge
       detect(1) := detect(0); -- other way to detect edges
       detect(0) := sig2 ; -- sig2 only !!
          else
             arrived <= '1';
          end if;
       end if;
       -- end if;
       end if;
    end process;
