13 years agofirst debounce significantly your 'sig' signal : very quite easy to write with other process with counter
* that counts to a fixed value if no 'sig' event happens * that be cleared if a 'sig' event happens. For example, clk is 20ns-periode (50MHz) and you want to not consider pulse < 100us. So counter for this will count to (100us/20ns = 5000) if no event happens. Just little but important corrections here :
process (reset, clk)
variable detect : STD_ULOGIC_VECTOR(1 downto 0);
-- variable count : UNSIGNED(8 downto 0); -- not used here
begin
if reset= '1' then
detect := "00";
counter <= (others => '0');
arrived <= '0';
final_sig <= '0';
sig1 <= '0';
sig2 <= '0';
count_flag<= (others => '0');
elsif rising_edge(CLK) then
sig1 <= sig;
sig2 <= sig1;
final_sig <= sig2;
-- rising_edge <= sig2 and not(final_sig); -- one way to detect rising_edge
-- count_flag<= count_flag+1;
-- if(count_flag > 3) then
detect(1) := detect(0); -- other way to detect edges
detect(0) := sig2 ; -- sig2 only !!
if (detect = "01") or (detect = "10") then -- detecting rising edge or falling edge
if (counter < req_dist(8 downto 1)) then
counter <= counter + 1;
else
arrived <= '1';
end if;
end if;
-- end if;
end if;
end process;
