13 years ago[ code]...[ /code]
thats what i done : (its does not work , still the same situation ... maybe the incoming signal ("sig") is bouncing like you sayed...) what do you suggest to try ? process (reset, clk) variable detect : STD_ULOGIC_VECTOR(1 downto 0); variable count : UNSIGNED(8 downto 0); begin if reset= '1' then detect := "00"; counter <= (others => '0'); arrived <= '0'; final_sig <= '0'; sig1 <= '0'; sig2 <= '0'; count_flag<= (others => '0'); elsif rising_edge(CLK) then sig1 <= sig; sig2 <= sig1; final_sig <= sig2; -- rising_edge <= sig2 and not(final_sig); -- count_flag<= count_flag+1; -- if(count_flag > 3) then detect(1) := detect(0); detect(0) := sig2 and not(final_sig); -- sig after 2 DFF to avoid metastibility if (detect = "01") or (detect = "10") then -- detecting rising edge or falling edge if (counter < req_dist(8 downto 1)) then counter <= counter + 1; else arrived <= '1'; counter <= (others => '0'); count_flag<= (others => '0'); end if; end if; -- end if; end if; end process;
