13 years agoHi,
Please Quote your code with [ code]...[ /code] You don't need "use ieee.std_logic_arith.all;"if(req_dist /= "0") then req_dist is a vector, i don't know how it is interpreted. Maybe you have metastability events. Put at least 2 D-FlipFlop on your signal "sig". Quite complicated to count signal edges. I suggest (not complete) :
process (reset, clk)
variable detect : STD_ULOGIC_VECTOR(1 downto 0);
variable count : UNSIGNED(8 downto 0);
begin
if reset_n = '1' then
detect := "00";
count := 0;
arrived <= '0';
elsif rising_edge(clk) then
detect(1) := detect(0);
detect(0) := sig; -- sig after 2 DFF to avoid metastibility
if (detect = "01") or (detect = "10") then -- detecting rising edge or falling edge
if count < req_dist(8 downto 1) then
count := count + 1;
else
arrived <= '1';
counter <= (others => '0');
end if;
end if;
end process;
