11 years agoSimple Signed Adder is complex to understand
Hi guys, still asking beginner questions, sorry. I have this code and cant figure out what the '0' in ('0' & cin) is doing. This is what I think:
Lets say we we need to do add two to negative four: (2)0010 + (-4)1101 where the answer is (-2)11110 (last bit '1' indicates the negative sign) so, (a_sig(n-1) & a_sig) 00010 + (b_sig(n-1) & b_sig) 11101 + ('0' & cin) 00 ans 11111 (which is incorrect) What am I getting wrong?http://www.alteraforum.com/forum//images/icons/icon8.png Also is this signed adder actually efficient cause lots of examples suggest loads of other ways to do it and I can't figure out which one to stick to or it depends on the application? library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity examples is generic(n : integer := 4); -- number of input bits port(a, b: in std_logic_vector(n-1 downto 0); cin: in std_LOGIC := '0'; sum: out std_LOGIC_VECTOR(n downto 0)); end examples; architecture add_sub of examples is signal a_sig, b_sig: signed(n-1 downto 0); signal sum_sig: signed(n downto 0); begin --convert to signed a_sig <= signed(a); b_sig <= signed(b); --add sum_sig <= (a_sig(n-1) & a_sig) + (b_sig(n-1) & b_sig) + ('0' & cin); sum <= std_logic_vector(sum_sig); end add_sub;
