RZhen11
6 years agoSignalTap node finder terribly slow (18.1 Standard Edition)
I'm working on an Arria10 design with about 30% fill, (i7-7820HQ @2.9GHz, 16GB RAM, Windows10)
Every time I want get a list of nodes (SignalTap: pre-synthesis) it takes more than 15mins+ to get the...
sstrell
6 years agoThis is after running Analysis & Elaboration from the Processing menu? Very strange.
What's actually happening during the 15 minutes where you're stuck?
#iwork4intel
RZhen11
6 years agoI have no clue what the tool is doing, at beginning I though the tool is dead. But it actually came out after a long wait.
I might have to recreate a new project from scratch .
- sstrell6 years ago
Before you do that, try quitting Quartus, deleting the db and incremental_db folders (if present) in your project directory, and re-run Analysis & Elaboration. Something could be corrupted in the compilation database that is causing the issue.
#iwork4intel
- RZhen116 years ago
Just to update, I've tried a with a newly created project.
Same thing, I can't believe if it's because my project is TOO BIG.
