RZhen11's avatar
RZhen11
6 years ago
SignalTap node finder terribly slow (18.1 Standard Edition)
I'm working on an Arria10 design with about 30% fill, (i7-7820HQ @2.9GHz, 16GB RAM, Windows10)
Every time I want get a list of nodes (SignalTap: pre-synthesis) it takes more than 15mins+ to get the list.
Please share your experience how to fix this.
  • sstrell's avatar
    sstrell
    This is after running Analysis & Elaboration from the Processing menu? Very strange.
    What's actually happening during the 15 minutes where you're stuck?
    #iwork4intel
    • SLabe's avatar
      SLabe
      Have you tried with a fresh Quartus project with a skeleton project to see if the behavior is the same?
    • RZhen11's avatar
      RZhen11
      I have no clue what the tool is doing, at beginning I though the tool is dead. But it actually came out after a long wait.
      I might have to recreate a new project from scratch .
      • sstrell's avatar
        sstrell
        Before you do that, try quitting Quartus, deleting the db and incremental_db folders (if present) in your project directory, and re-run Analysis & Elaboration. Something could be corrupted in the compilation database that is causing the issue.
        #iwork4intel
