15 years agoSignalTap Megawizard Crashes
OS: Windows Vista 32-bit
Quartus: 10.0 webpack Build 218 The megawizard crashes whenever the number of trigger bits in a signaltap block is set higher than 1. I've worked around it by hand editing the generated .cmp and .vhd. I generated the same megafunction on a linux installation of 10.0 and had no problems. I'm going through all this because signaltap has stoppped working since I installed 10.0. The megafunctions were originally generated with 9.0, so I have regenerated them with 10.0 to avoid an version conflicts. Unfortunately, stp still recognizes the core and sees everything via JTAG, but it will not let me set triggers. I've tried both webpack and subscription edition on linux, and webpack on windows. If anyone has had this problem and found a way around it, I'd love to hear about it.
