Altera_ForumHonored Contributor15 years agoSignalTap Megawizard Crashes OS: Windows Vista 32-bit Quartus: 10.0 webpack Build 218 The megawizard crashes whenever the number of trigger bits in a signaltap block is set higher than 1. I've worked around it by hand e...Show More
Recent DiscussionsConnection bit order between hierarchyFree Licence for Max+PlusIIMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)
