15 years agoIt may very well be a licensing issue. I obtained a new webpack license and verified talkback is enabled and still cannot set triggers.
The .stp file I generated with 9.1sp2 on windows loads fine on with the linux 10.0 version. It even picks up the falling edge trigger I set and saved and uses it to do the capture. So for now I can hand edit the .stp file to set triggers. Not ideal, but I can make progress on my project. I plan on getting a brand new subscription license in the near future...hopefully that will fix the problem.
