9 years agoSignalTap II issue
Here is debounce state machine:module debounce_explicit(input clk, reset, sw, output reg db_level, db_tick); //symbolic state declaration
localparam
zero = 2'b00,
wait0 = 2'b10,
one = 2'b11,
wait1 = 2'b01;
// number of counter bits (2'N * 20ns = 40ms)
localparam N = 21;
//localparam N = 15;
// signal declaration
reg state_reg, state_next;
reg q_reg;
wire q_next;
wire q_zero;
reg q_load, q_dec;
// FSMD state & data registers
always @(posedge clk, posedge reset)
if (reset)
begin
state_reg <= zero;
q_reg <= 0;
end
else
begin
state_reg <= state_next;
q_reg <= q_next;
end
// FSMD data path (counter) next—state logic
assign q_next = (q_load) ? {N{1'b1}} : ((q_dec) ? q_reg - 1 : q_reg);
// status signal
assign q_zero = (q_next == 0);
// FSMD control path next—state logic
always @*
begin
state_next = state_reg; // default state: the same
q_load = 1'b0; // default output: 0
q_dec = 1'b0; // default output: 0
db_tick = 1'b0; // default output: 0
case (state_reg)
zero:
begin
db_level = 1'b0;
if (sw)
begin
state_next = wait1;
q_load = 1'b1;
end
end
wait1:
begin
db_level = 1'b0;
if (sw)
begin
q_dec = 1'b1;
if (q_zero)
begin
state_next = one;
db_tick = 1'b1;
end
end
else // sw==0
state_next = zero;
end
one:
begin
db_level = 1'b1;
if (~sw)
begin
state_next = wait0;
q_load = 1'b1;
end
end
wait0:
begin
db_level = 1'b1;
if (~sw)
begin
q_dec = 1'b1;
if (q_zero) state_next = zero;
end
else // sw==l
state_next = one;
end
default: state_next = zero;
endcase
end
endmodule
And here is SignalTap simulation http://www.alteraforum.com/forum/attachment.php?attachmentid=13218&stc=1 After 2st firing of the input sw the "state machine" frozes definitely in "00" state. Moreover, after 1st sw firing, the "state machine" value is displayed in symbolic interpretation in SignalTap II, i.e. zero, wait0, one, wait1. After 2nd sw firing this symbolic interpretation disappears ... leaving place to numeric interpretation, i.e. 0 (as shown on the above image). So I have 2 questions: - why symbolic interpretation disappears
- is it possible to put into SignalTap the signals that present in the source code in order to debug "system machine" misbehavior. Actually only few signals are available for SignalTap.
--- Quote Start --- Run "Report Ignored Constraints" command in TimeQuest to see if all your SDC commands are accepted. After running "Report Unconstrained Paths" check which actual ports are unconstrained (In Report window see Unconstrained Paths -> Setup Analysis -> Unconstrained Input Ports or Unconstrained Output Ports). This way you will find out which ports are left unconstrained or there is some error in your SDC file. I am guesing that you will find that those two input ports are altera_reserved_tdi and altera_reserved_tms. You can also use set_false_path for those ports. For JTAG i use: create_clock -period "10 MHz" -name altera_reserved_tck [get_ports altera_reserved_tck] set_false_path -from [get_ports {altera_reserved_tdi}] set_false_path -from [get_ports {altera_reserved_tms}] set_false_path -to [get_ports {altera_reserved_tdo}] # Specify the JTAG clock in a group set_clock_groups -asynchronous -group altera_reserved_tck --- Quote End --- Yes, it's the case, the unconstraiuned inputs are altera_reserved_tdi and altera_reserved_tms. Concerning constraints for JTAG signals is it necessary to create altera reserved_clk, as it's already present ? https://www.alteraforum.com/forum/attachment.php?attachmentid=13258 Thanks - Altera_Forum
--- Quote Start --- I think you have to set Synchronizer identification option to AUTO in Settings -> TimeQuest Timing Analyzer. --- Quote End --- I've checked ... this option is set to auto, but metastability values still aren't calculated https://www.alteraforum.com/forum/attachment.php?attachmentid=13259 - Altera_Forum
Finally, Synchronization Register Chains resolved the problem.
I applied 2 flip-flops to sw input:
and then applied sw2 to state machine (instead of sw). However the signals sw1 and sw2 aren't accessible in signaltap ... only sync1, sync2. I suppose that sync1 and sync2 are actually sw1 and sw2 ? https://www.alteraforum.com/forum/attachment.php?attachmentid=13260reg sw1, sw2; DFF sync1 (.d(sw), .clk(clk), .clrn(1'b1), .prn(1'b1), .q(sw1)); DFF sync2 (.d(sw1), .clk(clk), .clrn(1'b1), .prn(1'b1), .q(sw2));
