yussuf_khalil's avatar
yussuf_khalil
4 years ago
Signal Tap with clock signal from different partition
I have a project with a reserved core partition in which I would like to analyze a set of signals. However, the clock signal that is used within that partition originates in the root partition. When trying to use the clock output defined in the root partition as a clock source for Signal Tap, it fails with error 16640 "You cannot tap nodes in different Partial Reconfiguration or Reserved Core regions with the same Signal Tap instance."
Using the clock input in my reserved core partition instead, I get
Warning(11175): Alt_sld_fab_1.alt_sld_fab_1.alt_sld_fab_1: SLD fabric agents are not connected as there are no hosts
Error(11176): Alt_sld_fab_1.alt_sld_fab_1: add_instance: Can't create component type altera_sld_agent_endpoint_tieoff
Error(11176): Alt_sld_fab_1.alt_sld_fab_1.alt_sld_fab_1.auto_signaltap_d2h.clock: auto_signaltap_d2h.clock must be connected to a clock output
What's the correct to tap signals in a partition where the clock signal stems from a different partition?
  • KennyT_altera's avatar
    KennyT_altera
    Not sure if you have any update on the below? If no, we shall close this case
  • Nurina's avatar
    Nurina
    We did not receive any response to the previous question/reply/answer provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
    Nurina
  • Sorry, I've been on vacation. It seems indeed that @sstrell's solution is what I was looking for. Thanks a lot!
