yussuf_khalil
4 years agoSignal Tap with clock signal from different partition
I have a project with a reserved core partition in which I would like to analyze a set of signals. However, the clock signal that is used within that partition originates in the root partition. When ...
- 4 years ago
You need to add the host and agent SLD JTAG bridge IP in the root and reserved partitions:
Is your Signal Tap in the root or reserved partition?
Nurina
4 years agoHello,
We did not receive any response to the previous question/reply/answer provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
