yussuf_khalil
4 years agoSignal Tap with clock signal from different partition
I have a project with a reserved core partition in which I would like to analyze a set of signals. However, the clock signal that is used within that partition originates in the root partition. When ...
- 4 years ago
You need to add the host and agent SLD JTAG bridge IP in the root and reserved partitions:
Is your Signal Tap in the root or reserved partition?
KennyT_altera
4 years agoNot sure if you have any update on the below? If no, we shall close this case
