JPark222's avatar
JPark222
6 years ago
Signal Tap II error (261009)
The sof file is programmed/configured successfully, but Signal Tap complains with rather a ridiculous error: (I followed up the guide - create/modify stp by GUI, save/recompile)
Error(261009): Cannot run Signal Tap Logic Analyzer. Signal Tap File is not compatible with the file programmed in your device. The expected compatibility checksum value is 0x5579E704; the value read from your device is 0x5579F714
Isn’t JTAG vindicated from the fact we configure FPGA successfully all the time? The programmer does not allow to check Verify box, only Program/Configure box, simply put, you can't click Verify box, although it is NOT "disabled/gray".
I’ve checked all cases I could find from internet about the Error, but nothing helps.
  • Sorry I didn't update sooner.
    The issue has been resolved by lowering JTAG frequency (default 24M to 6MHz) due to a rather long JTAG cable/connection. What confused me most was the success (or maybe "silent failure") of downloading sof at the default frequency.
  • sstrell's avatar
    sstrell
    It's not a JTAG issue necessarily. Your .stp file is not matching the Signal Tap settings that have been programmed in the device. Check your project settings and make sure the correct .stp file is being pointed to. Save your .stp file and recompile. Try programming the device with the new programming file directly from the .stp file (upper right corner of the file).
    #iwork4intel
    • JPark222's avatar
      JPark222
    • Raphy's avatar
      Raphy
      thank you ,but I aware all this .
      I only change the signals in the signal tap. nothing in the project.
      Regards Raphy
  • Raphy's avatar
    Raphy
    Hi.
    any change i did in signal tap , the project didn't run.
    it seems the device is programed ,but nothing happen.
