Signal Tap II error (261009)
- 6 years ago
Sorry I didn't update sooner.
The issue has been resolved by lowering JTAG frequency (default 24M to 6MHz) due to a rather long JTAG cable/connection. What confused me most was the success (or maybe "silent failure") of downloading sof at the default frequency.
It's not a JTAG issue necessarily. Your .stp file is not matching the Signal Tap settings that have been programmed in the device. Check your project settings and make sure the correct .stp file is being pointed to. Save your .stp file and recompile. Try programming the device with the new programming file directly from the .stp file (upper right corner of the file).
#iwork4intel
