Brickman
1 year agoSignal tap hdl instantiation
Hi I'm trying to use hdl instantiation flow for signal tap. I've successfully compiled the design, and created a matching stp file from the create\update menu. The issues I have regard the functi...
- 1 year ago
I can submit a feature request to the tool specialists to see if this functionality can be implemented for the HDL flow. However, whether the request is accepted will depend on the business justification.
By the way, which Quartus edition are you using—Pro or Standard?
If you're using the Standard Edition, the chances of this feature being supported are quite low, as most enhancements are prioritized for the Pro Edition.
Richard Tan
