Signal tap hdl instantiation
- 1 year ago
I can submit a feature request to the tool specialists to see if this functionality can be implemented for the HDL flow. However, whether the request is accepted will depend on the business justification.
By the way, which Quartus edition are you using—Pro or Standard?
If you're using the Standard Edition, the chances of this feature being supported are quite low, as most enhancements are prioritized for the Pro Edition.
Richard Tan
Thank you, please submit the feature request.
Sadly, I am using the standard edition.
Ron
I’ve submitted a feature request to the team for consideration.
By the way, could you share a bit more about why you prefer using the HDL instantiation flow over the GUI flow? For example, is it mainly for improved robustness, version control, or other reasons?
Understanding your perspective will help us better address your needs.
Richard Tan
