Signal tap hdl instantiation
Hi
I'm trying to use hdl instantiation flow for signal tap.
I've successfully compiled the design, and created a matching stp file from the create\update menu.
The issues I have regard the functionality of the stp file vs the GUI generated one:
I have 2 busses, one for data and one for trigger, I want to see only only unified bus, so I can alias ports in one place, is that possible?
In GUI mode, the unified trigger\data bus can also serve as qualifier input, but in the generated IP, I can only assign a qualifier input, that is hardly useful.
Any known solutions for these issues?
Thanks in advance
I can submit a feature request to the tool specialists to see if this functionality can be implemented for the HDL flow. However, whether the request is accepted will depend on the business justification.
By the way, which Quartus edition are you using—Pro or Standard?
If you're using the Standard Edition, the chances of this feature being supported are quite low, as most enhancements are prioritized for the Pro Edition.
Richard Tan
- sstrell
You can connect signals to both input busses of the IP but there will still be two busses since signals can selectively be used for data and/or triggering. This is done with the checkboxes in the Node List in the .stp file flow.
Another reason to not use the instantiation flow. Why can't you use the standard .stp file flow?
- Brickman
I understand I need to use 2 busses, but that seems a limitation in the IP generation GUI, or in the stp create tool, the question is, can I hack the outputs of these to tools, so I can work similar to the standard flow?
Reasons why I don't like to work with the standard flow:
QSF gets messy, hard to track with version control tools.Signals selection is more robust, signals don't change names, optimized away etc.
Backwards compatibility, if I change 1 signal I don't need to program again the FPGA (if it runs an old version), I can ignore that specific signal and use the others.
I've used the HDL instantiation with Vivado's Chipscope, and it worked flawlessly, I'm disappointed with Quartus support for this.
- sstrell
As far as signal names, you can either tap the pre-synthesis versions of your signals or if you’re using Pro, use the preserve for debug feature to preserve node names through to post-fit.
I’m not sure what you mean about the .qsf file getting messy. For Signal Tap with a .stp file, there’s only one setting that enables the feature and points to the file.
And I also don’t understand what you mean about backwards compatibility. You can set a signal during run time to don’t care so it no longer is needed to cause the logic analyzer to trigger.
- RichardT_altera
Thank you sstrell for answering.
Unfortunately, with HDL instantiation of Signal Tap, you cannot directly create a unified trigger/data bus that also serves as a storage qualifier in the same flexible way as the GUI-generated .stp file. The HDL-instantiated IP requires explicit port assignments for data, trigger, and qualifier, and does not support bus aliasing or unified port mapping in the .stp file as the GUI does.The HDL flow is less flexible for bus aliasing and unified port mapping compared to the GUI.
If you want a unified bus, you must create it in your RTL (e.g., concatenate data and trigger signals into one bus and connect that to both the data and trigger ports, or use the same signal for multiple ports). For the storage qualifier, you must explicitly connect the qualifier port to the desired signal in your RTL; you cannot assign it to a bus in the .stp file after generation.
Consider using the GUI flow if you need advanced aliasing or unified bus mapping.
Richard
- Brickman
Thank you Richard
I have used the same bus in my RTL for data and trigger, but than I still have to alias them separately in the stp, even worse, I will need to change my RTL for every qualifier change.
At this point I reverted to the GUI flow.
Is there a plan to make the instantiation flow usable in future versions? as a user (who is not involved in the development) This looks like a simple GUI improving task, since the functionality is already in the GUI flow.
Ron
- RichardT_altera
Richard Tan
- Brickman
Thank you, please submit the feature request.
Sadly, I am using the standard edition.
Ron
- RichardT_altera
I’ve submitted a feature request to the team for consideration.
By the way, could you share a bit more about why you prefer using the HDL instantiation flow over the GUI flow? For example, is it mainly for improved robustness, version control, or other reasons?
Understanding your perspective will help us better address your needs.
Richard Tan
- RichardT_altera
Since I have submitted the feature request to the tool specialist and no further action is required from my end, I will be transitioning this thread to community support.
If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Richard Tan
