NJackson's avatar
NJackson
4 years ago
Signal Tap causing Quartus to crash
I've recently upgraded to Quartus Standard Edition v21.1. I've noticed that when using Signal Tap, if I try to add State machine nodes, this will cause Quartus to crash and generate an error report. I added the report below.
Does anyone know of how to resolve this, or if they're having similar issues?
Problem Details
Error:
*** Fatal Error: Access Violation at 00007FFEACC49E5A
Module: quartus.exe
Stack Trace:
   0x179e59: QDialogButtonBox::button + 0x9 (Qt5Widgets)
    0xe4f8d: SEDQ_STATE_MACHINE_TABLE_VIEW::selectionChanged + 0x5d (sld_sedq)
   0x241036: QAbstractItemView::setSelectionModel + 0x326 (Qt5Widgets)
   0x284cee: QTableView::setSelectionModel + 0x9e (Qt5Widgets)
   0x240c0e: QAbstractItemView::setModel + 0x56e (Qt5Widgets)
   0x284224: QTableView::setModel + 0x204 (Qt5Widgets)
    0x1a10f: SEDQ_STATE_MACHINE_TABLE_VIEW::SEDQ_STATE_MACHINE_TABLE_VIEW + 0x15f (sld_sedq)
    0x9f195: SEDQ_STATE_MACHINE_DLG::on_init_dlg + 0x345 (sld_sedq)
    0x19f1c: SEDQ_STATE_MACHINE_DLG::SEDQ_STATE_MACHINE_DLG + 0xac (sld_sedq)
    0xa7c6d: SEDQ_VIEW::on_node_add_state_machine + 0x4d (sld_sedq)
   0x1fa79f: QMimeData::urls + 0x13af (Qt5Core)
     0x7116: QAction::activate + 0x136 (Qt5Widgets)
   0x161ee7: QMenu::actionGeometry + 0x457 (Qt5Widgets)
   0x161d55: QMenu::actionGeometry + 0x2c5 (Qt5Widgets)
   0x167348: QMenu::mouseReleaseEvent + 0xb8 (Qt5Widgets)
    0x3a0a5: QWidget::event + 0x145 (Qt5Widgets)
   0x1635bb: QMenu::event + 0x17b (Qt5Widgets)
    0x179ec: QApplicationPrivate::notify_helper + 0x13c (Qt5Widgets)
    0x156f0: QApplication::notify + 0x7d0 (Qt5Widgets)
   0x1da558: QCoreApplication::notifyInternal2 + 0xb8 (Qt5Core)
    0x18d51: QApplicationPrivate::sendMouseEvent + 0x331 (Qt5Widgets)
    0x62022: QSizePolicy::QSizePolicy + 0x2792 (Qt5Widgets)
    0x60276: QSizePolicy::QSizePolicy + 0x9e6 (Qt5Widgets)
    0x1598e: QApplication::notify + 0xa6e (Qt5Widgets)
    0x5b733: QGuiApplicationPrivate::processMouseEvent + 0x723 (Qt5Gui)
    0x46e0a: QWindowSystemInterface::sendWindowSystemEvents + 0x9a (Qt5Gui)
   0x2273bd: QEventDispatcherWin32::processEvents + 0xbd (Qt5Core)
    0x59b48: qt_plugin_query_metadata + 0x1db8 (qwindows)
   0x1d63b0: QEventLoop::exec + 0x1a0 (Qt5Core)
   0x163af7: QMenu::exec + 0x1c7 (Qt5Widgets)
   0x1638ea: QMenu::exec + 0x1a (Qt5Widgets)
    0x3cff3: SEDQ_VIEW::contextMenuEvent + 0x173 (sld_sedq)
    0x3a694: QWidget::event + 0x734 (Qt5Widgets)
    0x58797: SEDQ_VIEW::event + 0x47 (sld_sedq)
    0x15f26: QApplication::notify + 0x1006 (Qt5Widgets)
    0x6286e: QSizePolicy::QSizePolicy + 0x2fde (Qt5Widgets)
   0x1d924a: QCoreApplication::exec + 0x14a (Qt5Core)
     0x10bb: qgq_main + 0x8b (quartus)
    0x13638: msg_main_thread + 0x18 (CCL_MSG)
    0x1494e: msg_thread_wrapper + 0x6e (CCL_MSG)
    0x18520: mem_thread_wrapper + 0x70 (ccl_mem)
    0x12df1: msg_exe_main + 0xa1 (CCL_MSG)
     0x20c6: WinMain + 0x156 (quartus)
     0x16d2: __scrt_common_main_seh + 0x116 (quartus)
    0x17c23: BaseThreadInitThunk + 0x13 (KERNEL32)
    0x6d720: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus
Comment:
I tried to add state machine nodes in Signal Tap which caused Quartus to crash
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 21.1.0
Build: 842
Edition: Standard Edition
  • SyafieqS's avatar
    SyafieqS
    Nigel,
    Yes, I can reproduce the issue on Win 10,
    Can you try to compile using other machine and see if it is able to pass the flow
    and whether this is machine environment issue?
    • NJackson's avatar
      NJackson
      I've compiled the same design on another machine, and the issue with SignalTap still persists.
      When I revert to a previous version of Quartus (16.1) on the same machine, the issue with SignalTap is not there.
  • SyafieqS's avatar
    SyafieqS
    Nigel,
    Can we have a quick on this?
    I am not able to replicate this issue at my end with both OSes (Win/Linux) and other machine as well.
    I sent to you an email let me know if you are not able to attend.
  • TMayd's avatar
    TMayd
    I am seeing this same error with a project where I had no issues adding the state machine nodes using Quartus 18.1 Standard. When I upgraded to 21.1 I am crashing every time I try to add the state machine nodes to a design in signal tap.
  • SyafieqS's avatar
    SyafieqS
    Nigel,
    Thanks for having call with us and this issue is reproducible.
    I will forward this issue to developer for further debug.
    Will let you know if there is any update.
  • SyafieqS's avatar
    SyafieqS
    Nigel,
    I had filed to developer for further debug and might take sometimes.
    Will let you know and findings.
    Tyler,
    Yes, I am aware and I am seeing the same issue as well.
    Thanks for the feedback
  • SyafieqS's avatar
    SyafieqS
    Hi Nigel,
    I will put this to close pending and we can communicate via email.
    Let me know if there is any concern.
  • JLemo4's avatar
    JLemo4
    Same exact issue for me - I just tried updating to 21.1.1 from 21.1.0, and still trying to add state machine nodes crashes Quartus.
    Is there any update on this?
