NJackson
4 years agoSignal Tap causing Quartus to crash
I've recently upgraded to Quartus Standard Edition v21.1. I've noticed that when using Signal Tap, if I try to add State machine nodes, this will cause Quartus to crash and generate an error report. ...
SyafieqS
4 years agoNigel,
Yes, I can reproduce the issue on Win 10,
Can you try to compile using other machine and see if it is able to pass the flow
and whether this is machine environment issue?
NJackson
4 years agoHi,
I've compiled the same design on another machine, and the issue with SignalTap still persists.
When I revert to a previous version of Quartus (16.1) on the same machine, the issue with SignalTap is not there.
