ZatK
2 years agoset_output_delay in source-synchronous situation : not meeting timing
So I have a design which is exactly in this situation : The only difference is that the clock is coming from 'Board Device' as well instead of on the board. CLK period is 12.5 ns Dclock_to...
RichardT_altera
2 years agoDo you need further help in this case?
Are you ok to share the design (Project > Archive Project) with the timing failure so we can check the timing report?
Richard Tan
