8 years agoset design clock
Hi All,
I have hard time trying to create clock based process in Verilog. I am using mini board with EP2C5T144C8 chip. I rote a simple code ad checking output signals with scope. I assign clock pin to pin 17 according to schematic this is where 50 Mhz osc connected to. But I don't see any signals on scope. What I am doing wrong? module encoder (CLK,enc_out); input CLK; output enc_out; reg enc_out; integer cnt = 0; always @(posedge CLK) begin cnt = cnt+1; if(cnt<25000) enc_out = 1; else enc_out = 0; if(cnt==50000) cnt = 0; end endmodule5 Replies
Do not use integer type. Use a register instead.
reg [15:0] cnt; then in the clock process you must make some changes, like: cnt <= cnt + 16'd1; - Altera_Forum
Thank Cris72,
I tryed this and it doesn't help. Its even worse. this code is working - I see on scope enc_out following end_inp: always @(enc_inp)//posedge CLK) begin enc_out<=enc_inp; end but this one not: always @(posedge CLK) begin enc_out<=enc_inp; end I am lost.... - Altera_Forum
You definitely have no CLK signal.
Probably you have a bad pin assignment. - Altera_Forum
Why the 2nd always block works is coz, its no longer a clocked sequential block, but a combinational block. The output follows the input whenever there's a change in the input.
Try with a clock and reset, and also as Cris72 mentioned, check Pin assignments, use [15:0] instead of integers. Try the following code and check:module encoder ( clock, reset, // Its good to use a reset so that Flops are set to a known state. enc_out ); input clock; input reset; output enc_out; reg enc_out; reg count; always @(posedge clock or negedge reset) begin if(!reset) begin count <= 16'd0; end else begin count <= count + 16'd1; end end always @ (count) begin if (count ==16'd50000) enc_out <= 1'b0; else if (count < 16'd25000) enc_out <= 1'b1; else enc_out <= 1'b0; end endmodule - Altera_Forum
Cris72 ya - its look like I don't have right pin assignment. I checked schematic of board and find 50Mhz osc that going into pin17. So I assign pin clock pin 17. but its look like this is still wrong. I will try to find better documentation for this board.
I tried to find 50Mhz signal on pin directly with scope, but no luck. I don't understand why. eapenabrm thx for help, but why you are using not decimal numbers like cnt = 25000; but cnt = 16'd25000 does it matter?
