Oliver_I_Sedlacek
Contributor
2 years agoSDC input constraints for DDR ADC newbie question
I'm trying to set the SDC constraints for the DDR input from an LTC2386 ADC and I need a bit more guidance. I've watched Intel's tutorial video at https://www.youtube.com/watch?v=GItefNliYpM so with length matched clock and data traces clock skew should be zero. How do I do constraints for both positive and negative edges? Should I have two completely separate constraints?
TIA
- AdzimZM_Altera
"Should I have two completely separate constraints?"
- Yes, typically need to consider both the positive and negative edges separately because data is sampled on both edges of the clock.
"How do I do constraints for both positive and negative edges?"
- From my understanding, the idea roughly is like this,
- From data constraint, you need to identify the setup and hold times for the data relative to both the positive and negative edges of the clock.
- Use set_input_delay constraints to specify the setup and hold times for the data signals relative to clock edges.
- And then, you prolly need to do group and I/O contraints.
- So your SDC will have set input/output delay for positive and negative respectively
Adzim
- Oliver_I_Sedlacek
Contributor
Thanks, I'll dive deeper into that. I'm getting a lot of warnings that seem to do with separate p and n pins of the LVDS pair so I guess I need to figure out how to target the non-LVDS signals.
