SDC_ENTITY_FILE critical warnings
When building a platform designer based system using quartus pro 25.1 I see a number of the following warnings when running the fitter.
Critical Warning(22304): SDC_ENTITY_FILE '../../phoenix/DesignFiles/platform_designer/ip/print_sys/pcc3e/pcc2e_print_memory/altera_reset_controller_1924/synth/altera_reset_controller.sdc' was not applied. No matching entity: 'altera_reset_controller' in library: 'altera_reset_controller_1924'.
The altera_reset_controller is listed in the altera_reset_controller_1924 library under the quartus design units tab. Given this, why do these warnings occur?
Kind regards,
Graeme
I found that by changing the analysis order so that the first altera reset controller analyzed was from the qsys directory, not an ip directory, this problem did not occur
Graeme
