graememe
7 months agoSDC_ENTITY_FILE critical warnings
When building a platform designer based system using quartus pro 25.1 I see a number of the following warnings when running the fitter. Critical Warning(22304): SDC_ENTITY_FILE '../../phoenix/Design...
- 7 months ago
I found that by changing the analysis order so that the first altera reset controller analyzed was from the qsys directory, not an ip directory, this problem did not occur
Graeme
RichardT_altera
7 months agoPlease proceed with sstrell’s suggestion by re-adding the component and regenerating the HDL.
Should the issue persist, kindly share the .QAR file (Project → Archive Project) so that I can reproduce the warning behavior from my side.
Richard Tan
