GLous's avatar
GLous
8 years ago
RTL viewer problem with array of buses, it separates all bits.
I have an VHDL code that uses arrays of buses, I'm reading 10 groups of 4 ASICS of 16 bits each, the problem is that RTL is showing me each bit separately so is showing a gigantic diagram very difficult to follow and useless for documentation.
I'm using Quartus Pro 18.0
  • GLous's avatar
    GLous
    Merci, for now I have a workaround for documentation but makes me having extra "for generate loops" all over the code.
    I t seems that RTL viewer was not coded to understand arrays of arrays of std_logic_vectors, in the old altera forums there was a questions of 2010 with the same issue.
    Hope to hear from you soon,
    Guillermo
  • Vicky1's avatar
    Vicky1
    I suspect, it seems to be bug.
    Can you provide the project file(.qpf) so that we can replicate the issue?
    Best Regards
    Vikas Jathar
  • GLous's avatar
    GLous
    Hi Vikas,
    I'm trying to upload the qpf file but the web gets stuck so I copy here two qpf files, the first one is the project I have been doing that it was created with quartus standard edition on a linux and the new project I've created now because I saw that the qpf file was keeping information of the standard version and no the pro.
    STANDARD
    # Copyright (C) 2018  Intel Corporation. All rights reserved.
    # Your use of Intel Corporation's design tools, logic functions
    # and other software and tools, and its AMPP partner logic
    # functions, and any output files from any of the foregoing
    # (including device programming or simulation files), and any
    # associated documentation or information are expressly subject
    # to the terms and conditions of the Intel Program License
    # Subscription Agreement, the Intel Quartus Prime License Agreement,
    # the Intel FPGA IP License Agreement, or other applicable license
    # agreement, including, without limitation, that your use is for
    # the sole purpose of programming logic devices manufactured by
    # Intel and sold by Intel or its authorized distributors.  Please
    # refer to the applicable agreement for further details.
    # Quartus Prime
    # Version 18.0.0 Build 614 04/24/2018 SJ Standard Edition
    # Date created = 10:00:10  Juni 10, 2018
    QUARTUS_VERSION = "18.0"
    DATE = "10:00:10  Juni 10, 2018"
    # Revisions
    PROJECT_REVISION = "compactorV01"
    PRO
    # Quartus Prime
    # Version 18.0.0 Build 219 04/25/2018 SJ Pro Edition
    # Date created = 09:15:03  August 15, 2018
    DATE = "09:15:03  August 15, 2018"
    # Revisions
    PROJECT_REVISION = "UTDataProc"
    In both cases I see the same problem
  • Vicky1's avatar
    Vicky1
    Thanks & I appreciate your efforts but we need project file to replicate.
    Can you attach that project file(.qpf) as a zip?
    Best Regards
    Vikas Jathar
  • Vicky1's avatar
    Vicky1
    I could able to replicate the issue & presently it is unavailable.
    Once I get any inputs definitely I will reach to you.
    Best Regards
    Vikas Jathar
