RTL Simulation fails with: couldn't execute ip-setup-simulation: invalid argument
I am using Quartus Prime Pro Edition 25.3.1 on Windows 10/11.
RTL simulation fails immediately with the following error:
Error: Failed to run ip-setup-simulation: couldn't execute "ip-setup-simulation": invalid argument
Error: Simulation flow failed
Error(23031): Evaluation of Tcl script
c:/altera_pro/25.3.1/quartus/common/tcl/internal/nativelink/qnativesim.tcl unsuccessful
Additional stack trace:
Simulation TCL script failed with errorCode: 1
(procedure "iputf_call_script_gen" line 1)
invoked from within
"iputf_call_script_gen $spd_file_list"
I already checked the following:
- Same error occurs for all projects
- Same error occurs in Quartus Pro 25.1 and 25.3.1
- Same error occurs after deleting db/, incremental_db/, simulation/ folders
- PATH conflict removed (only one vsim exists in PATH)
- `vsim -version` shows:
"Questa Altera FPGA Edition-64 vsim 2025.2 Simulator"
- `where vsim` returns only:
C:\altera_pro\25.3.1\questa_fe\win64\vsim.exe
- `Generate Simulator Setup Script for IP` also fails
- IP regenerate fails with:
"Failed to retrieve Quartus project IP search paths"
I also noticed that Quartus reports:
"Questa Altera FPGA Edition simulator is not supported for simulation library compilation."
Questions:
1. Is Questa Altera FPGA Edition (questa_fe) unsupported for Quartus Pro 25.x NativeLink RTL simulation?
2. Is this a known issue with ip-setup-simulation or qnativesim.tcl?
3. Does Quartus Pro require Questa Intel FPGA Edition/full Questa instead of questa_fe?
4. Is there a workaround besides manually running Questa simulation scripts?
Thank you.
