RTL Simulation fails with: couldn't execute ip-setup-simulation: invalid argument
Questa Altera FPGA Edition is supported from Quartus Pro 24.3.1 onward, and RTL simulation should work correctly.
Have you setup the simulation feature before running the RTL simulation?
https://docs.altera.com/r/docs/683870/25.3/quartus-prime-pro-edition-user-guide-third-party-simulation/setting-up-the-run-simulation-feature
If the issue still persists, could you help to share the design .QAR file so I could duplicate the issue?
Richard Tan
I’m sorry that I cannot provide the .qsf file due to technology leakage/security concerns.
However, I managed to solve this issue.
The solution was simply to run Quartus with administrator privileges.
- RichardT_altera4 months ago
asdfasdf1 I’m glad you were able to resolve the issue, and thank you for sharing the solution. This will help others as well.
Richard Tan
