13 years ago
rom and ram
I'm stucked i dont know what to do
1 Testprotokol (verifiering och validering)
2 Deskribe with pulsediagrams (from ModelSim) and write and read cykel for RAM.
3 Deskribe med pulsediagram (from ModelSim) one read cykel for ROM
Test bench
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY uppgift_3b_vhd_tst IS
END uppgift_3b_vhd_tst;
ARCHITECTURE uppgift_3b_arch OF uppgift_3b_vhd_tst IS
-- constants
-- signals
SIGNAL addr_ram : STD_LOGIC_VECTOR(2 DOWNTO 0);
SIGNAL addr_rom : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL clk : STD_LOGIC:='0';
SIGNAL data_ram : STD_LOGIC_VECTOR(2 DOWNTO 0);
SIGNAL q_ram : STD_LOGIC_VECTOR(2 DOWNTO 0);
SIGNAL q_rom : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL we_ram : STD_LOGIC;
COMPONENT uppgift_3b
PORT (
addr_ram : IN STD_LOGIC_VECTOR(2 DOWNTO 0);
addr_rom : IN STD_LOGIC_VECTOR(1 DOWNTO 0);
clk : IN STD_LOGIC;
data_ram : IN STD_LOGIC_VECTOR(2 DOWNTO 0);
q_ram : OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
q_rom : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
we_ram : IN STD_LOGIC
END COMPONENT;
BEGIN
i1 : uppgift_3b
PORT MAP (
-- list connections between master ports and signals
addr_ram => addr_ram,
addr_rom => addr_rom,
clk => clk,
data_ram => data_ram,
q_ram => q_ram,
q_rom => q_rom,
we_ram => we_ram
clk<= not(clk) after 20 ns;
init : PROCESS
-- variable declarations
BEGIN
-- test protokoll case 1
WAIT FOR 100ns;
addr_ram <= "001";
-- test protokoll case 2
WAIT FOR 100ns;
addr_rom <= "10";
-- test protokoll case 3
WAIT FOR 100ns;
data_ram <= "011";
-- test protokoll case 4
WAIT FOR 100ns;
we_ram <= '1';
-- code that executes only once
WAIT;
END PROCESS init;
END uppgift_3b_arch;
    I'm not entirely sure what the exact problem you are asking about (as I assume english isn't your primary language)
    Try replacing:
    With:
    PROCESS
    BEGIN
        wait for 20 nS;
        clk <= not clk;
    END PROCESS;
    For anyone else who may want to see the unmodified code with proper indents:
    LIBRARY ieee;
    -- constants
    -- signals
        PORT
            clk         : IN STD_LOGIC;
    END COMPONENT;
    BEGIN
    i1 : uppgift_3b
        PORT MAP
            clk      => clk,
            q_ram    => q_ram,
            q_rom    => q_rom,
            we_ram   => we_ram
    init : PROCESS
    BEGIN
        WAIT FOR 100ns;
        addr_ram <= "001";
        WAIT FOR 100ns;
        addr_rom <= "10";
        WAIT FOR 100ns;
        data_ram <= "011";
        WAIT FOR 100ns;
        we_ram <= '1';
        WAIT;
    END PROCESS init;
    --- Quote Start ---
    Try replacing:
    With:
    PROCESS
    BEGIN
        wait for 20 nS;
        clk <= not clk;
    END PROCESS;
    --- Quote End ---
    Why did you suggest this change? the origional code is perfectly valid and will work exactle the same as the process. Is it just a question of coding style?
    Thank you very much for your help.I'm from sweden and i don't speak english very often.... with kind regards Per :)
    --- Quote Start ---
    --- Quote End ---
    I was not 100% sure if it would result in the same behavior. I guess I'm just used to seeing people using transport delays outside of processes and testbench clocks inside processes.
