I'm not entirely sure what the exact problem you are asking about (as I assume english isn't your primary language)
Try replacing:
clk<= not(clk) after 20 ns;
With:
PROCESS
BEGIN
wait for 20 nS;
clk <= not clk;
END PROCESS;
For anyone else who may want to see the unmodified code with proper indents:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY uppgift_3b_vhd_tst IS
END uppgift_3b_vhd_tst;
ARCHITECTURE uppgift_3b_arch OF uppgift_3b_vhd_tst IS
-- constants
-- signals
SIGNAL addr_ram : STD_LOGIC_VECTOR(2 DOWNTO 0);
SIGNAL addr_rom : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL clk : STD_LOGIC:='0';
SIGNAL data_ram : STD_LOGIC_VECTOR(2 DOWNTO 0);
SIGNAL q_ram : STD_LOGIC_VECTOR(2 DOWNTO 0);
SIGNAL q_rom : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL we_ram : STD_LOGIC;
COMPONENT uppgift_3b
PORT
addr_ram : IN STD_LOGIC_VECTOR(2 DOWNTO 0);
addr_rom : IN STD_LOGIC_VECTOR(1 DOWNTO 0);
clk : IN STD_LOGIC;
data_ram : IN STD_LOGIC_VECTOR(2 DOWNTO 0);
q_ram : OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
q_rom : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
we_ram : IN STD_LOGIC
END COMPONENT;
BEGIN
i1 : uppgift_3b
PORT MAP
-- list connections between master ports and signals
addr_ram => addr_ram,
addr_rom => addr_rom,
clk => clk,
data_ram => data_ram,
q_ram => q_ram,
q_rom => q_rom,
we_ram => we_ram
init : PROCESS
-- variable declarations
BEGIN
-- test protokoll case 1
WAIT FOR 100ns;
addr_ram <= "001";
-- test protokoll case 2
WAIT FOR 100ns;
addr_rom <= "10";
-- test protokoll case 3
WAIT FOR 100ns;
data_ram <= "011";
-- test protokoll case 4
WAIT FOR 100ns;
we_ram <= '1';
-- code that executes only once
WAIT;
END PROCESS init;
END uppgift_3b_arch;
