10 years ago
ROM and RAM connection
Im trying to connect ROM with RAM blocks,for this Im write top level entity and connected output of ROM with RAM
This is code for ROM
LIBRARY ieee;    USE ieee.std_logic_1164.all;
     use STD.textio.all;
    ENTITY sync_rom IS
     PORT (
      clock: IN std_logic;
      address: IN integer range 0 to 511;
      data_a_i: OUT integer range 0 to 255;
       data_b_q: OUT integer range 0 to 255
    END sync_rom;
    ARCHITECTURE rtl OF sync_rom IS
    BEGIN
    PROCESS (clock)
     BEGIN
     IF rising_edge (clock) THEN
      CASE address IS
       WHEN 0 =>
            data_a_i <= 128;
            data_b_q <= 128;
       WHEN 16 =>
             data_a_i <= 128;
             data_b_q <= 128;
         WHEN 70 =>
             data_a_i <= 128;
             data_b_q <= 128;
         WHEN 400 =>
             data_a_i <= 128;
             data_b_q <= 128;
       WHEN OTHERS  =>
              data_a_i <= 0;
             data_b_q <= 0;
      END CASE;
     END IF;
     END PROCESS;
END rtl;
This is code for RAM
library ieee;use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity dp_ram_rbw_scl is
  generic (
    DATA_WIDTH : integer := 256;
    ADDR_WIDTH : integer := 256
  port (
-- common clock
    clk    : in  std_logic;
    -- Port A
    we_a   : in  std_logic;
    addr_a : in  std_logic_vector(ADDR_WIDTH-1 downto 0);
    data_a : in  std_logic_vector(DATA_WIDTH-1 downto 0);
    q_a    : out std_logic_vector(DATA_WIDTH-1 downto 0);
    -- Port B
    we_b   : in  std_logic;
    addr_b : in  std_logic_vector(ADDR_WIDTH-1 downto 0);
    data_b : in  std_logic_vector(DATA_WIDTH-1 downto 0);
    q_b    : out std_logic_vector(DATA_WIDTH-1 downto 0)
end dp_ram_rbw_scl;
architecture rtl of dp_ram_rbw_scl is
  -- Shared memory
  type mem_type is array ((2**ADDR_WIDTH)-1 downto 0) of std_logic_vector(DATA_WIDTH-1 downto 0);
  shared variable mem : mem_type;
begin
-- Port A
  process(clk)
  begin
    if(clk'event and clk = '1') then
      q_a <= mem(conv_integer(addr_a));
      if(we_a = '1') then
        mem(conv_integer(addr_a)) := data_a;
      end if;
    end if;
  end process;
-- Port B
  process(clk)
  begin
      q_b <= mem(conv_integer(addr_b));
      if(we_b = '1') then
        mem(conv_integer(addr_b)) := data_b;
      end if;
    end if;
  end process;
end rtl;
after this this I write TOP level entity
    use ieee.numeric_std.all ;
    use ieee.math_real.all ;
    use ieee.math_complex.all ;
entity ROMRAM is
    port (
       data_b_q: OUT integer range 0 to 255;
        ADDR_WIDTH : integer := 256;
        clk    : in  std_logic;
        q_b    : out std_logic_vector(DATA_WIDTH-1 downto 0);
end ROMRAM;
architecture rtl of ROMRAM is
--- Component decalarartion
Component sync_rom is
    port(
end component;
Component dp_ram_rbw_scl is
generic (
         port (
        clk    : in  std_logic;
        addr_a : in  std_logic_vector(DATA_WIDTH-1 downto 0) ;
        data_a : in  std_logic_vector(DATA_WIDTH-1 downto 0) ;
        addr_b : in  std_logic_vector(ADDR_WIDTH-1 downto 0) ;
        data_b : in  std_logic_vector(DATA_WIDTH-1 downto 0) ;
end component;
for all : sync_rom use entity work.sync_rom(rtl);
--for all : dp_ram_rbw_scl use entity work.dp_ram_rbw_scl(rtl);
--Signal     data_a_i: integer range 0 to 255;
--data_b_q_a: std_logic_vector(255 downto 0);--interanal signals
begin
--inst : dp_ram_rbw_scl port map ( addr_a=> addr_a,
--clk=> clk,we_a=>we_a,data_a=>data_a,addr_b=>addr_b,data_b=>data_b,we_b=>we_b);
q_a<= addr_a and data_a;
-- Component Instantiation
C1: sync_rom Port map (
                                clock => clock,
                                address =>address,
                                data_a_i =>data_a_i,
                                data_b_q =>data_b_q
C2: dp_ram_rbw_scl Port map (
                                    clk=>clk,
                                    we_a=>we_a,
                                    addr_a=>addr_a,
                                    data_a =>data_a,
                                    q_a=>q_a,
                                    we_b=>we_b,
                                    addr_b=>addr_b,
                                    data_b =>data_b,
                                    q_b=>q_b
                                data_a_i<=to_integer ( unsigned (data_a));
                                data_b_q<=to_integer ( unsigned (data_b));
end rtl;
But this code doesnt work/Could you please give me some hints for solution? I want to connect data_a_i(ROM) with data_a(RAM) and data_b_q(ROM) with data_b(RAM)
I get next errors
Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "addr_a" must have actual or default value
Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "data_a" must have actual or default value
Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "addr_b" must have actual or default value
Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "data_b" must have actual or default value
    rom does not need data input or write. ram needs them so check your wiring again.
    For RAM,I need to connect addr_a _b ports?with adddress port from ROM?and data_a and data_b?
    now, I competed this code
    library ieee;
    entity ROMRAM is
    generic(
    		  DATA_WIDTHi : integer := 8;
            ADDR_WIDTHi : integer := 8);
        port (
            CLOC: IN std_logic;
            ADD: IN integer range 0 to 511;
    		  --data_a : in std_logic_vector(DATA_WIDTHi-1 downto 0);
    		  --data_b : in std_logic_vector(DATA_WIDTHi-1 downto 0);
            --data_a_i : out integer range 0 to 255;
    		  --data_b_q : out integer range 0 to 255;
            --clk    : in  std_logic;
            we_ai   : in  std_logic;
            addr_ai : in  std_logic_vector(ADDR_WIDTHi-1 downto 0);
            q_ai   : out std_logic_vector(DATA_WIDTHi-1 downto 0);
            we_bq   : in  std_logic;
            addr_bq : in  std_logic_vector(ADDR_WIDTHi-1 downto 0);
            q_bq    : out std_logic_vector(DATA_WIDTHi-1 downto 0));
    end ROMRAM;
        port(
    end component;
    generic (
            DATA_WIDTH : integer := 8;
            ADDR_WIDTH : integer := 8
        port(
            clk    : in  std_logic;
            addr_a : in  std_logic_vector(ADDR_WIDTH-1 downto 0) ;
    end component;
    Signal     data_a_i_i: integer range 0 to 255;--interanal signals
    signal dt_ai: std_logic_vector(7 downto 0);
    Signal     data_b_q_i: integer range 0 to 255;--interanal signals
    signal dt_bq: std_logic_vector(7 downto 0);
    begin
                                    clock => CLOC,
                                    address =>ADD,
                                    data_a_i =>data_a_i_i,
                                    data_b_q =>data_b_q_i
    C2: dp_ram_rbw_scl
    Port map (
                                        clk=>CLOC,
                                        we_a=>we_ai,
                                        addr_a=>addr_ai,
                                        data_a =>dt_ai,
                                        q_a=>q_ai,
                                        we_b=>we_bq,
                                        addr_b=>addr_bq,
                                        data_b =>dt_bq,
                                        q_b=>q_bq
    										  dt_ai<=std_logic_vector(to_unsigned(data_a_i_i,dt_ai'length));
    										  dt_bq<=std_logic_vector(to_unsigned(data_b_q_i,dt_bq'length));
    											--data_a_i<= to_integer(unsigned(data_a));
    											--data_b_q<= to_integer(unsigned(data_b));
    											--data_a_i <= std_logic_vector(to_unsigned(data_a_i,data_a'length));
    											--data_a=> data_a_i_i
    end rtl;
    --- Quote Start ---
    how is it looks now?
    --- Quote End ---
    code ok but overall idea unclear. What do you put in rom (with dual port output). You then address rom from outside and address ram from outside. What is the purpose.
    I also suggest (strongly) changing the name cloc to clock or clk just for consistency. check your rom code address range(now 0~255).
    --- Quote Start ---
    After this I want to add this block in fft_engine(http://opencores.org/project,versatile_fft)
    In ROM when fft see the next add like 0,16,70,400 in this addresses we put 128 values,for other we put just 0
    Data from ROM should go to the RAM
    --- Quote End ---
    But I expect a proper fft core to require just input stream +plus start of frame/end of frame etc. So why do you care about addressing issues you mentioned
