10 years agoROM and RAM connection
Hello, Im trying to connect ROM with RAM blocks,for this Im write top level entity and connected output of ROM with RAM This is code for ROM LIBRARY ieee; USE ieee.std_logic_1164.all;
10 years ago --- Quote Start --- After this I want to add this block in fft_engine(http://opencores.org/project,versatile_fft) In ROM when fft see the next add like 0,16,70,400 in this addresses we put 128 values,for other we put just 0 Data from ROM should go to the RAM --- Quote End --- But I expect a proper fft core to require just input stream +plus start of frame/end of frame etc. So why do you care about addressing issues you mentioned
