RiscFree IDE Installation
- 1 year ago
Hi @Njoroge,
Greetings, just checking in to see if there is any further doubts in regards to this matter.
Hope your doubts have been clarified.
Best Wishes
BB
Not sure. I never started it from the Start menu because the command shell was always required for Nios II as well.
- Njoroge1 year ago
The software packages that have their own setup files eg the Advanced Link Analyzer or even the Questa packages, once installed used to have their shortcuts and uninstallation shortcuts appear in the Start menu and I thought that was good to at least show what add on software packages you have. With the newest release, the RiscFree IDE doesn't which I interpreted as a problem with the installation, not that it has to do anything with how the software runs. It does however start from the nios v shell as you said.
