11 years agoRecommand approach to do the pin assignments
If I didn't use pin planner to do pin assignments before hand. After I finish my design, then I need to do pin assignments, what is the recommend approach to do pin assignments in this case? It looks like there should be 3 approaches:
1. pin planner 2. Assignment editor 3. editing qsf file directly Pin planner may be not the good choice since it should be used in plan stage. The problem of assignment editor is in each row, I can only edit one property of pins (maybe I use in wrong way?). So it looks like editing the qsf file is the best approach. Anyone has some suggestions ? Thanks.
