FvM
22 days agoWhere to place custom .xml flash device files for Quartus Programmer?
Hello, to use flash devices that are not natively supported by Quartus programmer, a .xml device file (pgm_flash_xxxx.xml) describing the programming algorithm must be supplied along with the progra...
FvM
21 days agoHello,
Some new insights
Default custom database location is ./ (current working directory).
Thus discussed option2 (supplying pgm_flash_xxxx.xml file in same location as programming file) works with Add File in Quartus Programmer and default ./ setting.
Custom database location is stored in quartus2.ini for each installed Quartus version separately, found in top Users folder.
Frank
