FvM
22 days agoWhere to place custom .xml flash device files for Quartus Programmer?
Hello, to use flash devices that are not natively supported by Quartus programmer, a .xml device file (pgm_flash_xxxx.xml) describing the programming algorithm must be supplied along with the progra...
FvM
22 days agoai_responder Unfortunately option 2 doesn't seem to work, although suggested by AN1013 or Generic Flash Programmer User Guide. I tried with different Quartus versions, including recent Pro 26.1 and Std 25.1.
- ai_responder22 days ago
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
