Timing constraints for external logic that takes input from, and outputs to an FPGA
The internal delays would be set up based on the external delay. That's how set_input_delay and set_output_delay work. If you define the external delay with set_max_delay and set_min_delay, it should work the same way.
I added the following constraints.
set_max_delay -from [get_ports output_port] -to [get_ports input_port] 10.368 set_max_delay -from [get_ports output_port] -to [get_ports input_port] 0
After rerunning compilation and checking timing, Delays and the Clock Skews for the Registers immediately before the output ports and after the input ports are as follows:
- Clock Delay for the output register is 8.263ns
- The data delay from the output register to the output port is 8.302ns
- The maximum external propagation delay is 10.368ns
- Clock Delay for the input register is 7.773ns
- The data delay from the input port to the input register is 9.817ns
- The clock is running at 120MHz = 8.333ns
The question is, what kind of analysis is being performed on this path now? The ports are currently unconstrained so it is not doing a synchronous analysis.
Doing the math here, there is a negative slack of:
Data Required Time - Data Arrival Time = Slack
(8.333+7.773+9.817) - (8.263+8.302+10.368 ) = -1.01ns
It's not doing that analysis nor reporting the "violation". I expect it to report the violation because the maximum external delay would cause the data to arrive after the latch clock edge.
- sstrell2 years ago
Why do you have two set_max_delay constraints with different values? The second one should be set_min_delay.
Your data required calculation is incorrect. It should be (8.333 + 7.773 - tsu), whatever the setup timing requirement of the input register is.
Your data arrival time calculation is missing the data input delay. It should be (8.263 + 8.302 + 10.368 + 9.817) but that obviously makes things worse. The input and output delays and clock delays are way too big. The input and output registers are getting placed very far from the I/O to have data delays over 8 and 9.
Are you using a PLL? Have you tried using the fast I/O register assignments to use the registers located directly in the I/O cells?
And you're saying the tool still says these I/O are unconstrained?
- TuckerZ2 years ago
Typed the command twice. The first is the correct one.
Yes, thank you for the corrections. It is even worse than what I originally typed out.
The implementation details are not of importance since I am working on those still. The tool should have certainly caught the timing issues at this point considering such abysmal timing.
The tool does say these I/O are unconstrained.
I'm not sure the set_max_delay command did what I wanted it to do considering it didn't catch this. Any Insight?
