zjj's avatar
zjj
18 days ago
how to use design partition
for one big project,  I want to use bottom-up flow with tcl mode is similar to xilinx OOC.  the project has f top A, it instance B0, B1, B2,..B10 that has same entity B. after studying compile guidel...
  • RichardT_altera's avatar
    13 days ago
    You may refer to the Design Block Reuse Flows in Section 1.5 of the Quartus Prime Pro Edition User Guide:
    https://docs.altera.com/r/docs/683247/25.1.1/quartus-prime-pro-edition-user-guide-block-based-design/answers-to-top-faqs
    In this flow, you (as the Developer) compile the B project and export a partition snapshot as B.qdb. You then create a black‑box file for module B.
    In the Consumer (top‑level) project A, the consumer adds the B black‑box file as a source in the project. After design elaboration, the consumer defines each instance of B as an independent design partition and assigns the exported B.qdb file to all B instances through the Design Partitions window.
    Richard Tan
