How to create a new component that instantiates a IP variant in PD?
I want to connect an Avalon stream multiplexer to an Avalon S2MM Memory FIFO using a dual clock FIFO that has different input and output width. My data packet from the Avalon stream multiplexer is 128-bit and the S2MM Memory FIFO only supports 32-bit data when it is configured S2MM (I want to stream the data packet to HPS). Since the current Avalon stream FIFO dual clock does not support misaligned input and output width, I created a custom Avalon Stream DC FIFO the wraps a DCFIFO (128->32) IP. I wanted to use the Component Editor in Platform Designer to make the wrapped AVS DCFIFO an custom IP so I can instantiate it in Platform Designer. Here is my question, can I add the *.ip IP variant file along the HDL top-level file into the Component Editor file list to create the IP? If not, what are some alternate approaches to make instantiating HDL + IP comb in Platform designer happen?
To answer your question can you add the .ip IP variant file directly into the Component Editor file list to create a custom IP?
No, you cannot simply add the .ip IP variant file (created by the IP Catalog) directly to the HDL file list in the Component Editor to create a new custom IP.
The Component Editor is designed to work with HDL files and expects a top-level HDL module. IP variant files generated by the IP Catalog contain metadata and references for the IP core, but are not HDL source files themselves. As a result, Platform Designer does not treat them as synthesizable modules and cannot instantiate them directly in a new custom component.You may need to use alternate approaches for combining HDL and IP Instantiation
1. Use the _hw.tcl Composition Callback to Instantiate IP
- Write a custom _hw.tcl file for your component.
- Use the add_hdl_instance command within a composition or elaboration callback to instantiate the DCFIFO IP (or other IP core) as a child instance in your custom component.
- The IP core must be available in the project (usually generated from IP Catalog).
- You can parameterize the child IP using set_instance_parameter_value.
- This method allows you to wrap HDL logic around IP instances and export interfaces as needed.
Example (simplified):
package require -exact qsys 14.0 set_module_property name my_custom_dc_fifo set_module_property COMPOSITION_CALLBACK composed_component proc composed_component {} { add_hdl_instance my_dcfifo_inst altera_dc_fifo set_instance_parameter_value my_dcfifo_inst WIDTH_IN 128 set_instance_parameter_value my_dcfifo_inst WIDTH_OUT 32 # Export interfaces, connect clocks/resets as needed set_interface_property stream_in EXPORT_OF my_dcfifo_inst.stream_in set_interface_property stream_out EXPORT_OF my_dcfifo_inst.stream_out # Add other logic/interfaces as necessary }
- See Section 3.9. Create a Composed Component or Subsystem for details.
2. Use HDL Wrapper Module and Reference the IP Core
- Create a top-level HDL module (SystemVerilog or VHDL) that instantiates the DCFIFO IP (referencing its generated module name).
- Add this wrapper HDL file to the Component Editor, specifying the top-level ports and interfaces.
- The IP variant and supporting files must be present in the project directory.
- This approach is more manual but sometimes simpler for small projects.
3. Use Fileset and Elaboration/Composition Callbacks for Parameterized HDL + IP
- For more advanced setups, use fileset callbacks and elaboration/composition procedures in your _hw.tcl to dynamically select files, interfaces, and parameters based on the component's configuration.
- This is required if your component’s HDL or child IPs change based on user parameters.
- KennyT_altera
you may find the answer here https://docs.altera.com/r/docs/683609/25.1.1/quartus-prime-pro-edition-user-guide-platform-designer/control-file-generation-dynamically-with-parameters-and-a-fileset-callback 3.9. Create a Composed Component or Subsystem
- YZhou98
Hi Kenny,
I want to make a component IP with following system. The composed component does not seem to support what I need.
Thank you!
- KennyT_altera
Is there further question?
- KennyT_altera
- wa_itd
For 1 and 3, you need to use a composition callback, which cannot be used alongside an elaboration callback. Am I correct in concluding then, that it is impossible to embed an IP in a custom component if you'd like to control the IP interfaces dynamically (for example, hiding an interface based on a generic)?
Option 2 did not work for me, unfortunately.
- KennyT_altera
Your understanding of callback exclusivity is correct: if a component uses COMPOSITION_CALLBACK, Platform Designer does not allow ELABORATION_CALLBACK on the same component.
However, this does not mean that embedding IP in a custom component is impossible when dynamic interface control is needed. Instead, you need to select one supported architecture:
Path A (Recommended for dynamic hide/show interfaces):
Use a static or generated custom component with ELABORATION_CALLBACK, and instantiate child IP using add_hdl_instance.Path B (Composed subsystem style):
Use COMPOSITION_CALLBACK with add_instance, and handle conditional interface/export decisions within the composition flow (without using elaboration callback).The limitation is that you cannot use both callbacks in a single component—not that you cannot embed IP with dynamic behavior.
Regarding your Option 2 issue:
Here is a practical, GUI-first troubleshooting flow:- Start with a minimal example: Create one custom component, one child IP, and a parameter toggle (e.g., for hiding an interface).
- Choose a single model: Use either the "Composed" or "Static/Generated" approach—do not mix assumptions from both in one test.
- Monitor Instantiation Messages: In Component Instantiation, review and resolve all warnings before regenerating.
- Sync checks: Use IP file vs. component synchronization warnings to catch stale parameterization after edits.
- Validate parameter toggling: Re-run validation for each parameter value (toggle ON/OFF) and confirm the presence or absence of the interface as expected.
- Debug wrapper-based flows: If issues occur, first verify the top-level entity name, port directions and widths, and file compile order, as these are common sources of problems.
- Check child IP embedding: Ensure each instance has a unique variation name and is regenerated after parameter changes.
- Incremental complexity: Export one interface at a time. Start with clock/reset, then add data buses, increasing complexity step-by-step.
