How to create a new component that instantiates a IP variant in PD?
- 7 months ago
To answer your question can you add the .ip IP variant file directly into the Component Editor file list to create a custom IP?
No, you cannot simply add the .ip IP variant file (created by the IP Catalog) directly to the HDL file list in the Component Editor to create a new custom IP.
The Component Editor is designed to work with HDL files and expects a top-level HDL module. IP variant files generated by the IP Catalog contain metadata and references for the IP core, but are not HDL source files themselves. As a result, Platform Designer does not treat them as synthesizable modules and cannot instantiate them directly in a new custom component.You may need to use alternate approaches for combining HDL and IP Instantiation
1. Use the _hw.tcl Composition Callback to Instantiate IP
- Write a custom _hw.tcl file for your component.
- Use the add_hdl_instance command within a composition or elaboration callback to instantiate the DCFIFO IP (or other IP core) as a child instance in your custom component.
- The IP core must be available in the project (usually generated from IP Catalog).
- You can parameterize the child IP using set_instance_parameter_value.
- This method allows you to wrap HDL logic around IP instances and export interfaces as needed.
Example (simplified):
package require -exact qsys 14.0 set_module_property name my_custom_dc_fifo set_module_property COMPOSITION_CALLBACK composed_component proc composed_component {} { add_hdl_instance my_dcfifo_inst altera_dc_fifo set_instance_parameter_value my_dcfifo_inst WIDTH_IN 128 set_instance_parameter_value my_dcfifo_inst WIDTH_OUT 32 # Export interfaces, connect clocks/resets as needed set_interface_property stream_in EXPORT_OF my_dcfifo_inst.stream_in set_interface_property stream_out EXPORT_OF my_dcfifo_inst.stream_out # Add other logic/interfaces as necessary }
- See Section 3.9. Create a Composed Component or Subsystem for details.
2. Use HDL Wrapper Module and Reference the IP Core
- Create a top-level HDL module (SystemVerilog or VHDL) that instantiates the DCFIFO IP (referencing its generated module name).
- Add this wrapper HDL file to the Component Editor, specifying the top-level ports and interfaces.
- The IP variant and supporting files must be present in the project directory.
- This approach is more manual but sometimes simpler for small projects.
3. Use Fileset and Elaboration/Composition Callbacks for Parameterized HDL + IP
- For more advanced setups, use fileset callbacks and elaboration/composition procedures in your _hw.tcl to dynamically select files, interfaces, and parameters based on the component's configuration.
- This is required if your component’s HDL or child IPs change based on user parameters.
you may find the answer here https://docs.altera.com/r/docs/683609/25.1.1/quartus-prime-pro-edition-user-guide-platform-designer/control-file-generation-dynamically-with-parameters-and-a-fileset-callback 3.9. Create a Composed Component or Subsystem
- YZhou987 months ago
Hi Kenny,
I want to make a component IP with following system. The composed component does not seem to support what I need.
Thank you!
- KennyT_altera7 months ago
Is there further question?
- KennyT_altera6 months ago
Closing the case since no further question.
- wa_itd3 months ago
For 1 and 3, you need to use a composition callback, which cannot be used alongside an elaboration callback. Am I correct in concluding then, that it is impossible to embed an IP in a custom component if you'd like to control the IP interfaces dynamically (for example, hiding an interface based on a generic)?
Option 2 did not work for me, unfortunately.
- KennyT_altera2 months ago
Do you have further queries?
