fitter error in Quartus Prime Pro 25.1.0.
You're confusing AS_DATA0 (for active serial configuration) and DATA0 used as part of the 32-bit bus for the FPP configuration scheme. Check what configuration scheme you have selected in the Device and Pin options (Assigments menu -> Device).
You don't mention if this is a commercially available dev kit (if so, which one?) or your own design. Details on configuration schemes are here: https://www.intel.com/content/www/us/en/docs/programmable/683775/current/configuration-design-security-and-remote-29047.html
Hello, sstrell-san.
I don't think you've correctly understood my inquiry.
I'm assigning a signal to Pin_AE5. I'm getting a message saying that the Quartus Fitter cannot assign that pin to "~ALTERA_DATA0~". However, "~ALTERA_DATA0~" for this device should be Pin_Y4. The fitter pin is clearly wrong. There is an error in the device data used by the fitter.
I think the problem is on the Quartus fitter side.
Incidentally, the configuration scheme is AS mode.
Regards, Hidetaka,
