Questions: Intel oneAPI 24.2 with DE10-Agilex and Related Environment setup
- 1 year ago
Hello Feng,
I'm sorry for the trouble you've been having. We test the compiler against a reference BSP on devkit hardware, but it is ultimately up to board vendors to validate that their hardware and firmware work with the latest oneAPI compiler release. If Terasic only validates 2022.1, then that is the only version that is officially known to work with that card.
Having said that, my colleague was able to successfully compile your design using
- Ubuntu 20.04.6 LTS
- oneAPI 2024.1
- Quartus® Prime Pro 21.2
- the Terasic BSP
He saw the same license issue with oneAPI 2024.2.
I suggest as a last resort that you remove other versions of the Quartus® Prime and oneAPI software, leaving only oneAPI 2024.1 and Quartus® Prime Pro 21.2.
I have personally experienced issues with license files that were not configured correctly. For example, a Quartus fixed license only works for a machine whose ethernet MAC address matches the ID embedded in the license file. This means that a license file for my workstation will not work for your workstation. From your Terasic email chain that you shared, it sounds like you may be using a liceense0046.dat from a different machine, rather than one that they specifically made for you:
How did you get the license0046.dat before? There are not any previous emails communication with you that we send you this license file.
Hello Feng,
- oneAPI 2024.1
- the Terasic BSP
Hi whitepau
I wanted to express my sincere thanks for your patient guidance over the past month. With your help, I've completed the machine reset and test file generation.
Your expertise and willingness to help have been invaluable, and I truly appreciate all your support.
Feng
- whitepau_altera1 year ago
Contributor
Thank you Feng!
Were you able to generate a bitstream using 2024.1 and Quartus® Prime 21.2 by removing other versions?For what it's worth, I was actually able to generate a bitstream using oneAPI 2024.2 and Quartus® Prime 21.2 on one of our lab machines using a fresh installation. For the record, this was with -DPART=4 in the fpga_compile code sample.
# Set up environment $ source /opt/intel/oneapi/2024.2/oneapi-vars.sh --force $ export PATH="$PATH:/opt/intel/FPGA_pro/21.2/quartus/bin" $ which quartus /opt/intel/FPGA_pro/21.2/quartus/bin/quartus $ cd oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fpga_compile/build_2024.2/ $ aoc -version Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler Version 2024.2.1 Build 8907061a4a7bb8b03783e9f52adc9762aaf4d91d Pro Edition Copyright (C) 2024 Intel Corporation $ echo $LM_LICENSE_FILE <...>/license0046.dat # use CMake to generate build script and build FPGA device image $ cmake .. -DPART=4 -DFPGA_DEVICE=de10_agilex:B2E2_8GBx4 -- The CXX compiler identification is Clang 19.0.0 -- Check for working CXX compiler: /opt/intel/oneapi/2024.2/bin/icpx -- Check for working CXX compiler: /opt/intel/oneapi/2024.2/bin/icpx -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Detecting CXX compile features -- Detecting CXX compile features - done -- Sources file part4_dpcpp_lambda_buffers/src/vector_add.cpp -- Configuring the design to run on FPGA board de10_agilex:B2E2_8GBx4 -- Additional USER_FPGA_FLAGS= -- Additional USER_FLAGS= -- Additional USER_INCLUDE_PATHS=../../../../include -- Additional USER_LIB_PATHS= -- Additional USER_LIBS= -- Configuring done -- Generating done -- Build files have been written to: /home/whitepau/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fpga_compile/build_2024.2 $ time make fpga [ 33%] To compile manually: /opt/intel/oneapi/2024.2/bin/icpx -I../../../../../include -fsycl -fintelfpga -Wall -qactypes -DFPGA_HARDWARE -c ../part4_dpcpp_lambda_buffers/src/vector_add.cpp -o CMakeFiles/fpga.dir/part4_dpcpp_lambda_buffers/src/vector_add.cpp.o To link manually: /opt/intel/oneapi/2024.2/bin/icpx -fsycl -fintelfpga -qactypes -Xshardware -Xstarget=de10_agilex:B2E2_8GBx4 -reuse-exe=/home/whitepau/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fpga_compile/build_2024.2/vector_add.fpga -o vector_add.fpga CMakeFiles/fpga.dir/part4_dpcpp_lambda_buffers/src/vector_add.cpp.o [ 33%] Built target displayFPGACompileCommands [ 66%] Linking CXX executable vector_add.fpga warning: -reuse-exe file '/home/whitepau/oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fpga_compile/build_2024.2/vector_add.fpga' not found; ignored aoc: Compiling for FPGA. This process may take several hours to complete. Prior to performing this compile, be sure to check the reports to ensure the design will meet your performance targets. If the reports indicate performance targets are not being met, code edits may be required. Please refer to the oneAPI FPGA Optimization Guide for information on performance tuning applications for FPGAs. [100%] Built target fpga real 139m54.261s user 358m27.793s sys 27m7.830s- Feng-Y-281 year ago
Hi whitepau
By now, the 2024.1.0 oneapi toolkit has been working in Ubuntu20.04 with Quartus® Prime 21.2.
Thanks for your test result; a perfect test with 2024.2.1 oneAPI.
Is it possible to provide the docker image of such an environment(2024.2.1 oneapi) for DE10_Agilex?
Additionally, does the work environment work in Ubuntu22 or ubuntu20?
Feng
Contributor
My machine is Ubuntu 20.04.
no docker image is available.
Hi whitepau
After a refresh installation, the 2024.2.1 oneapi toolkit can also support DE10_Agilex.
I tried almost all different reinstall parts combinations (software/BSP/driver) in the past year from time to time and failed.
The specific reason why this has not been fixed. However, the system-level fresh installation can fix the tcl error.
Feng
Contributor
thanks for checking, Feng. I'm glad you have a working installation now.
