Questions: Intel oneAPI 24.2 with DE10-Agilex and Related Environment setup
- 1 year ago
Hello Feng,
I'm sorry for the trouble you've been having. We test the compiler against a reference BSP on devkit hardware, but it is ultimately up to board vendors to validate that their hardware and firmware work with the latest oneAPI compiler release. If Terasic only validates 2022.1, then that is the only version that is officially known to work with that card.
Having said that, my colleague was able to successfully compile your design using
- Ubuntu 20.04.6 LTS
- oneAPI 2024.1
- Quartus® Prime Pro 21.2
- the Terasic BSP
He saw the same license issue with oneAPI 2024.2.
I suggest as a last resort that you remove other versions of the Quartus® Prime and oneAPI software, leaving only oneAPI 2024.1 and Quartus® Prime Pro 21.2.
I have personally experienced issues with license files that were not configured correctly. For example, a Quartus fixed license only works for a machine whose ethernet MAC address matches the ID embedded in the license file. This means that a license file for my workstation will not work for your workstation. From your Terasic email chain that you shared, it sounds like you may be using a liceense0046.dat from a different machine, rather than one that they specifically made for you:
How did you get the license0046.dat before? There are not any previous emails communication with you that we send you this license file.
please make sure you install the FPGA support package for 2024.2 and beyond
According to Terasic's documentation, you should use Quartus® Prime 21.2 with their BSP.
The work enviro for OneAPI: 24.2 on DE10-Agilex is should be as follows:
22.04 20.04 Ubuntu
Quartus® Prime Pro 22.3-24.2 21.2
BSP version: B2E2_8GBx4
OneAPI 2024.2 base toolkit
FPGA Support Package version 2024.2
I searched for the FPGA support package 2024.2 but could not find it on the Intel website today, which may have been provided one week ago.
The download link is only for 25.0. However, the oneAPI base toolkit provided the different versions, 24.2/25.0, for download.
Feng
