c-thaler
2 years agoQuesta simulation hangs (nondeterministic)
I run a Questa simulation for an IP core from the command line on a Linux server. Usually, the simulation finishs successfully. But every now and then the simulation hangs. When it hangs, I can see ...
TingJiangT_Intel
Contributor
2 years agoHi Thaler, I tried to modify the file as what you showed, but it caused error during simulation as follow:
** Error: (vcom-11) Could not find work.th_dnx_genericram.
Can you share the '.do' file works in your side, thanks
c-thaler
2 years agoI was able to fix the do file. Now the simulation can be run. Please find attached the do file.
Unfortunately Quartus generates absolute paths in it. But if you compare your and my do-file you should be able to do the same changes to yours.
